How to Apply a License to a Linux System
jthyne
Post by jthyne »
I have the Premium Edition Combo Pack and I wanted to see how I could add the license to a Linux system (so it isnt the trial anymore). How do I do that? Can I just copy the Syncovery.ini from a Windows system or is it more than that? Thanks!
jthyne
Re: How to Apply a License to a Linux System
Post by jthyne »
I found it. When I try to apply my license information to the linux system from my license file (v9), i get the following message:
"The program settings could not be saved: Registration Name And/Or Code Did Not Match."
the license is entered via the Program Settings dialog, tab sheet "Misc, License".
The registration code for Linux is different from the Windows or Mac one. When ordering, you receive two different codes. Please choose the correct one. If you didn't get a separate Linux code, please contact support@syncovery.com.
Thanks!
jthyne
Post by jthyne »
Thanks for the quick reply. I will send an email in. When I got the license, it only had one license for the combo pack.
Thanks again for helping!
