syncing to koofr via webdav
aries
Post by aries »
Has anyone gotten syncovery working with koofr via webdav? I enter all the fields and can't read directories to start the sync.
Re: syncing to koofr via webdav
I have tested it with the latest Syncovery 9.43a and it works fine.
An older version may have had an older OpenSSL version that was incompatible.
If there are any issues, you can also try to choose Library 2: SBB SSL. This library uses SecureBlackBox SSL, which is an alternative to OpenSSL.
