Problem With File Paths
morfeas99
Post by morfeas99 »
Hi and thanks in advance for your help.
I use syncovery 3 years now with no problem. I use two way sync with smart tracking (google drive).
I experience after the update (9.0) a strange problem that that program reads file paths incorrectly and therefore uploads (or deletes) unexpectedly and wrong (Chinese symbols appear).
Its not happening all the time but randomly. I can send you a log file but I don't know how.
Please advise.
Thanks for the help.
morfeas99
Re: Problem With File Paths
Post by morfeas99 »
5:22:04 μμ Reading right-hand side directly: \42\42469
5:22:05 μμ Reading right-hand side directly: \42\42474
5:22:05 μμ Reading right-hand side directly: \42\42477
5:22:06 μμ Reading right-hand side directly: \42\42478
5:22:07 μμ Reading right-hand side directly: \42\42480
Path corrected from FILECOUNT\0
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\100
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\100
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\102
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\102
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\104
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\104
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\106
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\106
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\108
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\108
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\11
to \†琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\11
Path corrected from †琠䙜䱉䍅問呎ぜ਍ 㜰෗ ﷩\111
which version exactly? Can you try the latest version 9.38k?
morfeas99
Post by morfeas99 »
I am at the latest version 9.38k!
could you delete the cloud cache files in C:\ProgramData\Syncovery\Database?
If it doesn't help, maybe send a complete log file to support@syncovery.com?
