Removing checkmarks automatically after "Run Checked Profiles" job is finished
Redwood
Post by Redwood »
Checkmarks stay in place after "Run Checked Profiles" job is finished.
It is confusing. I suppose checkmarks should be removed automatically.
Please add an option for that.
Re: Removing checkmarks automatically after "Run Checked Profiles" job is finished
Thanks for the suggestion. To run jobs like that, please do not use the checkmarks. Just make your selection by clicking on the whole profile bars, und using Shift and Ctrl to make a bigger selection. That selection can easily be undone. The idea behind the checkmarks is that they stay because some customers repeatedly need to run the same profiles via checkmarks and don't want to repeat the selection every time.
Redwood
Post by Redwood »
Thanks! Understood. I was not aware of that ability.
