Some wrong behavior when "Profile Settings -> Include Subfolders -> Selected" option is active
Redwood
Post by Redwood »
Choose some subfolders on the left-hand side using Profile Settings -> Include Subfolders -> Choose Folders and Files.
Then create new subfolder. As a result it will be selected automatically to be synchronized with the right-hand side. Go to "Choose Folders and Files" to see that it is selected.
I beleive it is wrong behavior. New created subfolder should not be selected automatically for synchronization if "Include Subfolders" option choosed.
Re: Some wrong behavior when "Profile Settings -> Include Subfolders -> Selected" option is active
you can remove the option to add new subfolders automatically in the top right side of the selection dialog.
Redwood
Post by Redwood »
Thanks! I was confused because that option is placed right under right-hand side. May be it will be better to move it to another place.
