Error Operation Cancelled
kengstrom
Post by kengstrom »
When running the Syncovery Service I get this error:
The profile is run by the Syncovery Service.
Left Side Volume Name: *****
Right Side Volume Name: *****
Error Operation Canceled @ 0000000001DB0ED6 Checkpoints: DEA-TM/DEA-TM
The synchronization was prepared but not carried out.
Error Operation Canceled @ 0000000001DB0ED6 Checkpoints: DEA-TM/DEA-TM, preparation not OK.
Any thoughts on why this would occur?
Thank you in advance!
Re: Error Operation Cancelled
the process is being terminated. Can you check if this still happens with the latest Syncovery version? Which one do you currently have?
kengstrom
Post by kengstrom »
See the attachment if more information is needed but it says 9.33d build 189.
can you update to Syncovery 9.35 - and if the problem remains, please send a largely unabridged log file to support@syncovery.com?
Thanks.
