Progress bar disappeared, recommended steps?
PMcKenzie2004
Post by PMcKenzie2004 »
On Windows 10, I no longer get a progress bar when running any profile. I looked through settings and the .ini file, but could not bring it back. Is there a simple solution?
Thank you
Re: Progress bar disappeared, recommended steps?
I assume that a dialog appears offscreen? The best solution in Syncovery 9 would be to click the Gears toolbar button, then Running Options, and chooose:
X Run Profile in Main Window
PMcKenzie2004
Thanks, I hadn't upgraded to version 9 either, but I did that and then your solution worked.
