Profiles run unexpectedly
johnliddle
Post by johnliddle »
I have several profiles to run in the evening after I finish work.
I do not have "run on windows login" or "run missed daily jobs ... when scheduler starts" ticked on the "more" tab.
But recently these profiles have begun to run when I login in the morning.
How do I stop this from happening please.
Re: Profiles run unexpectedly
can you send a log file from one of the unexpected runs to support@syncovery.com? Then I can check your settings, Syncovery version etc.
johnliddle
Thanks Tobias ... there's no log file generated. I assume there's an option to turn on log files?
Where do I do that please.
on the Program Settings dialog, tab sheet Logs.
Which Syncovery version do you have? Can you do Help->Check for Update?
johnliddle
Thanks, I'll send a log file later in the week.
And I have 9.31a build 171.
I see 9.32b is available, so will download and install this.
I'm not sure if it's related, but the new Syncovery 9.33 fixes an issue where the scheduler would sometimes run jobs at start-up, rather than using the scheduled interval to calculate the next intended run time.
