No such file or directory on Linux ARM
patanne
Post by patanne »
I am having an issue running SyncoveryCL on Linux on an ODROID-HC2, which uses the ODROID-XU4 platform.
The unit uses an 8-core ARMv7. Below is a dump of one core for brevity. Also there is a dump of uname & dpkg.
root:# cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 3 (v7l)
BogoMIPS        : 36.00
Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 3
root:# uname -a
Linux ns-0c6e 4.9.103-odroidxu4 #1 SMP PREEMPT Tue May 29 03:38:14 PDT 2018 armv7l GNU/Linux
root:# dpkg --print-architecture
armhf
Following this info I downloaded the armhf version of Syncovery, Syncovery-9.31-armhf.deb.
During installation and subsequent execution I am getting,
root:# /usr/lib/Syncovery/SyncoveryCL
-bash: /usr/lib/Syncovery/SyncoveryCL: No such file or directory
After confirming proper chmod I did another test to be sure it wasn't a dependency, even though the message should/would be different.
root:# strace /usr/lib/Syncovery/SyncoveryCL
execve("/usr/lib/Syncovery/SyncoveryCL", ["/usr/lib/Syncovery/SyncoveryCL"], [/* 21 vars */]) = -1 ENOENT (No such file or directory)
fstat64(2, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 0), ...}) = 0
write(2, "strace: exec: No such file or di"..., 40strace: exec: No such file or directory
) = 40
getpid()                                = 13452
exit_group(1)                           = ?
+++ exited with 1 +++
I have seen this before when installing a 32-bit app/package on 64-bit Linux, either by accident or because you have no choice; where you try to execute a file that is clearly there but you are told it is not. You have to then follow a process to support multi-architecture.
My questions is, what am I missing? It feels as if I have installed the wrong architecture, yet all the above output tells me I have installed the proper version.
Re: No such file or directory on Linux ARM
can you enter
ldd /usr/lib/Syncovery/SyncoveryCL
and also,
file /usr/lib/Syncovery/SyncoveryCL
These will give us additional info.
patanne
Post by patanne »
Here you go...
root:# ldd /usr/lib/Syncovery/SyncoveryCL
        not a dynamic executable
root:# file /usr/lib/Syncovery/SyncoveryCL
/usr/lib/Syncovery/SyncoveryCL: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.3, for GNU/Linux 2.0.0, stripped
thanks! Does the file /lib/ld-linux.so.3 exist?
patanne
Post by patanne »
It does not exist in /lib though it does exist in /lib/arm-linux-gnueabihf, which is in /etc/ld.so.conf.d/arm-linux-gnueabihf.conf, so I thought nothing of it.
Adding a symlink fixes the issue.
ln -s /lib/arm-linux-gnueabihf/ld-linux.so.3 /lib/ld-linux.so.3
thanks that's good to hear!
