Synchronization Preview Column Widths
JamesG
Post by JamesG »
I double-clicked the filename column header border to set the column width. The with is now wider than the window and is hiding columns to the right and there is no horizontal scrollbar.
How can I reduce the that column's width so I can see the columns to the right again?
Re: Synchronization Preview Column Widths
in Syncovery 9, you can click on a column header to reset the column widths. I will also add this to the next Syncovery 8 update.
What you can do is edit Syncovery.ini and remove any lines that contain
SyncPreviewWidths
