Run script after..
GeorgB
Run script after..
Post by GeorgB »
Hi all,
I wrote a little powershell script to rename a file after it was copied but don`t think Syncovery supports powershell scripts?
Hence the question, anybody have an idea how to achive the renaming in whatever sript langue supported?
All I need is to rename a file called Hig2.hcw to Hig2_[date in ddmmyy format].hcw
Pretty simple really, if you kow how.
or, alternately, how can I get my powershell script to run?
tried just the path & script name, and powershell path & script name, none worked
Tx.
Re: Run script after..
ideally, this would be done with a PascalScript like the following. You can enter it in the profile via the PascalScript checkmark on the Job tab sheet.
See also: https://www.syncovery.com/pascalscript
  if isFolder then
    Result:=FileName
  else
    Result:=ChangeFileExt(FileName,'')+'_'+DateTimeToStrWithFormat(Now,'ddmmyy')+ExtractFileExt(FileName);
To actually run a Powershell script, you need to use a command line similar to this:
PowerShell.exe -Command C:\scripts\test.ps1
GeorgB
Post by GeorgB »
Thank you, I missed the " -Command " between my powershell and the script.
Will give it a try.
