Slow File Listing
wesdou
Slow File Listing
Post by wesdou »
I am new to Syncovery. I've got a profile that takes hours to get the file listing. This just isn't feasible. What can I do to speed this up? These are Windows shares on a wide area network. I've emailed support about settings for performing real-time sync but have heard nothing back (this was probably over a month ago). I am about 20 days in of my 30 day trial. If I can't get something figured out I will need to look for a different option.
Re: Slow File Listing
I think you need to install the Syncovery Remote Service on the other end to help build the listing.
Please see
(see especially "Configure Checksummer and Remote Lister", and "Using the Remote Listing Feature")
https://www.syncovery.com/documentation ... /fastlist/
I didn't see your support request, feel free to send a new email to support@syncovery.com if problems remain.
wesdou
Post by wesdou »
I believe I have everything set up according to your suggestions. It is still terribly slow. I am at a loss. I want this profile to two way real time sync as well as a scheduled run once a day. It never gets a chance to do that because it spends the entire day getting file listings.
Can you send a few log files to support@syncovery.com?
There is surely unnecessary overhead that can be removed.
If there is confidential data in the logs, you may need to edit them before sending.
wesdou
Post by wesdou »
I sent you an email. Let me know if you do not get it. Thanks!
