Moved files
c_cooper88
Moved files
Post by c_cooper88 »
I'm testing out the syncing and I can't get Syncovery to detect moved files from left to right.
I've created a Test1 folder on Left with a file in it which syncs fine to Right. I then create a Test2 subfolder and move the file into it on Left. The sync copies the new subfolder onto Right but then copies the file from Test1 into Test2 but does not move it so there is now two copies of the test file.
I've tried using standard copying and Smart tracking with it configured to adjust file locations on right side but to no success.
Cheers,
Chris
Re: Moved files
please use Exact Mirror for one-way syncs. It should then work fine.
c_cooper88
Re: Moved files
Thanks, that seems to have solved it!
