Permission issues since upgrade to ver 12 (on Linux)
CDR224
Post by CDR224 »
Since I upgraded to version 12 on my Fedora KDE Desktop edition, I can't sync anymore with an smb share on my NAS (which is mounted under my home folder). Neither when using the mount point, nor directly setting the SMB://... path work (I can't even get the shared folders displayed anymore).
I have no issue to access the shares boths ways from the file manager (same user).
Here's one example error from the log:
File path : /home/carlo/NAS/Photography/Photos Carlo/2026/10/2026-10-06 Sweden - Torneträsk to Norway - Tromsø/D20261006002.MP4
Opening error: 5 = Permission Denied
15:24:55: Opening error, Permission Denied
(/home/carlo/NAS/Photography/Photos Carlo/2026/10/2026-10-06 Sweden - Torneträsk to Norway - Tromsø/D20261006003.MP4)
Error getting status (5): /home/carlo/NAS/Photography/Photos Carlo/2026/10/2026-10-06 Sweden - Torneträsk to Norway - Tromsø/D20261006003.MP4, Error Code: 5 (Permission Denied) - trying direct API copying
I can of course manually copy the files between the NAS and the laptop (same user again). Only Syncovery can't.
I also get lots of messages from SELinux concerning SyncoveryCL, but those should not be blocking.
Re: Permission issues since upgrade to ver 12 (on Linux)
I think this is caused by SELinux. A question:
I think /home/carlo/NAS/Photography/Photos Carlo/2026/10 is a local folder and not a mounted SMB path? So Syncovery doesn't have access to your local files, and it is not an SMB problem. The Linux system prevents access to your files. Most customers end up having to turn off SELinux. But I hope to find a better solution some time in the future.
Did you try our new internal SMB client?
You should type the path as
smb://servername/sharename/foldername
and click the SMB button and give Syncovery the username and password.
It will then surely connect successfully. If not, can you share the SMB errors from the log file, or send a log file to support@syncovery.com?
Thanks.
CDR224
Post by CDR224 »
Hi!
Please re-read my first post. I get the permission denied whether I use the mount point ("/home/carlo/NAS/Photography") or the direct smb path ("smb://server"). In the latter case, I don't even get the shares listed (also permission denied).
I can access both paths any other way, just not through Syncovery (with the same user account).
CDR224
Post by CDR224 »
Ok, disabling SELinux solves all problems. Looks like that's more of a PITA than useful ...
