As the attached .pdf shows, 4 of my profiles (CIC WD Media, Glyph A, Glyph B and Glyph C) have lost the volume letter to the RightPath which are 4 separate external 7200rpm USB 3.0 backup drives. If there was nothing on those drives, I would rename them in Windows Disk Management, but I am being cautious because that might conflict with the Syncovery protocol.
I am wondering if I should just "Edit" each profile. I can browse via File Explorer from the profile to locate its backup. Or is it better to create new Profiles. All of these worked the last time I backed up.
I couldn't find any advice in Best Practices or among Support topics here. I should add that all profiles were created in Windows 10 Pro and now I am in 11 Pro.
Thank you for your attention.
Jayasri
Renaming right-side (backup) volume
- Syncovery Profiles.jpg (176.03 KiB) Viewed 1488 times
Re: Renaming right-side (backup) volume
Syncovery isn't very sensitive here. You can do it as you wish. As long as Syncovery finds the destination, it will be fine.
To avoid the depenency on drive letters (which can change), you can instead type the volume label into Syncovery.
For example, you can replace
E:\FolderName
with
CIC WD Media:\FolderName
If that is the drive's volume label. Then Syncovery will find the drive regardless of drive letter.
E:\FolderName
with
Thank you very much, Tobias. I hope this helps others.
