Hello everyone,
I'm currently evaluating Syncovery 11.17.0 on an ASUSTOR NAS (Linux ARM64) for versioned backups and point-in-time restoration.
Most features work very well, including file versioning, preserving deleted files with their complete version history, and restoring older versions from both the regular backup and a separate deleted-files archive.
However, I'm having trouble reproducing an exact historical directory state.
### Backup configuration
- Exact Mirroring, left to right
- Timestamp-based versioning with an `Older` folder
- Separate archive for deleted files
- Up to 1,000 versions per file
- Remember deletion dates
### Restore configuration
- Standard synchronization, right to left
- `KeepMultipleVersions=Yes`
- `UseVersioningFolder=Yes`
- `VersionTimestampNaming=Yes`
- `RestoreDeletedItems=Yes`
- `UseTargetDate=Yes`
- Restore destination is a new, empty folder
### Reproducible test
I created a new file, `ZeitTest.txt`, and performed two backups:
| Event | Time (October 14, 2026) |
| Version A created | 18:12:48 |
| Version A backed up | 18:13–18:14 |
| Version B created | 18:15:13 |
| Version B backed up | 18:15–18:16 |
I then tested three restore target dates:
| Target date/time | Actual result | Expected result |
| 18:10:00 | Version A selected | File should not exist |
| 18:14:30 | Version A selected | Correct |
| 18:17:00 | Version B selected | Correct |
**The issue is that Syncovery selects the oldest available version even when the requested restore time is earlier than the creation of that file.**
The behavior is reproducible with Syncovery 11.15.8 and 11.17.0, including a completely new restore profile.
I have also verified that file modification timestamps are preserved correctly. The detailed file-list-building log confirms that Syncovery correctly recognizes the `Older` folder and the separate deleted-files archive.
### Questions for the community
1. Has anyone successfully used *Target Date for Restore* to reconstruct an exact historical directory state, including excluding files that were created after the selected date?
2. Is there an additional setting or a recommended combination of filters that I might have overlooked?
3. Does Syncovery intentionally fall back to the oldest available file version when the selected restore date precedes all available versions?
4. If this is a known limitation, what approach do you use for reliable point-in-time restoration?
I would prefer to retain Syncovery's efficient file-based versioning rather than create multiple complete backup copies.
Any practical experience or configuration examples would be appreciated. I can provide the complete profile settings and detailed logs if helpful.
Thanks in advance!
