"Run Upon Windows Login" is not working if "Run Upon Shutdown" is also selected
ricoh83
Post by ricoh83 »
If the background scheduler is set to "Run Upon Windows Login" then it does not run if also "Run Upon Shutdown or Reboot" is selected. "Run upon Windows Login" works only if it's selected and "Run Upon Shutdown or Reboot" is unticked. Trying 2 way sync to Google Drive. Tried disabling fast startup but that did not help. Syncovery version 12.4.6. Windows 10 Home. Real-time sync is not required. Auto-Start Background Scheduler With Windows Login is enabled.
