Unattendend delete all is ok
Stefan
Post by Stefan »
If your Syncovery runs in unattendend mode (e.g. windows server or something like that), you can set a limit in percent of how much Syncovery is allowed to delete. But if you want to allow Syncovery to delete everything, you need to specify a property inside the syncovery ini file.
(Be careful, read the FAQ entry provided in this post!)
Default location of the "Syncovery.ini" file in Windows: C:\ProgramData\Syncovery\Syncovery.ini
  1. Stop all your Syncovery instances (desktop client and all running instances, do not forget the icon in the tray - next to the clock)
  2. Open the "Syncovery.ini" file in your default editor
  3. Follow the FAQ entry: https://www.syncovery.com/documentation ... irmations/
Re: Unattendend delete all is ok
Thanks for posting these steps!
One added piece of information, the latest Linux version allows to import configuration strings in INI style too, so you could create a small text file like this:
[Main]
UnattendedDeleteAllIsOK_IfDelPercIs100=YES
And import it via the new button on the Program Settings dialog, tab sheet "Startup".
