I'm running Syncovery version 11.15.4 (build 204) on Synology. If possible, there are two small UI tweaks that would greatly improve its QoL for me:
1 - I use the notes field on the Information tab to display some detailed information about the backup job, but the default size of this field is too small. Every time I open the profile settings, I have to resize the field a bit (an operation that has some odd bugs, but works). Is it possible to make the default size of this field proportional to the size of the profile dialog, or at least have it remember its previous size?
2 - The profiles list view defaults to showing 15 profiles. I have 16, and it's nice to have a single glance at all my profiles. I can do this if I change it to show 20 rows (via the controls at the bottom), but this setting is not saved. Would it be possible to add a setting to choose the default number of profiles to display on one page, or at least have the web view remember the last used setting?
Thanks so much!
