Rclone support
Re: Rclone support
I am seriously considering it, yes.
Re: Rclone support
That sounds great. “Drime,” a relatively new cloud storage service from France, can be accessed using Rclone.
Syncovery Premium Family, Win 10
Re: Rclone support
the new version 12 beta 6 now supports Drime. You can choose it as one of the protocols/clouds.
You can authenticate either with email and password or with email and API token.
Rclone will be added next, and then a few more native integrations.
Re: Rclone support
Version 12 Beta 7, featuring Rclone support, is now available on my website.
You can now select Rclone as an alternative to other clouds; then, by clicking the "Settings" button, you can access the Rclone Web GUI to link your cloud account.
Once connected, you can use the upper "Browse" button to select the rclone Remote, and the lower one to select a specific folder.
It works for me.
The user interface might still be a little rough around the edges at times, but we are continuing to fine-tune it. However, once you have it up and running, I believe it works very well.
It works for me.
Re: Rclone support
Syncovery 12 has now been fully released, with Rclone included and fully integrated, plus a native Drime connector. I think that the native connectors should usually be preferred over going thru Rclone, because that's an additional API layer.
