Update errors on QNAP
Axel-Larator
Post by Axel-Larator »
Hello everyone,
I am trying to install the latest version on my NAS TS-133 or TS-233. Currently running version 9.38e. Tried all four available ARM versions with the following results.
App installation [App Centre] Failed to install Syncovery Remote Service 11.9.1. The installation package is incompatible. Use the compatible package.
App installation [App Centre] Failed to install SyncoveryCL 11.12.0. The installation package is incompatible. Use the compatible package. x19 x31 x41
What can I do?
Re: Update errors on QNAP
these devices are 64-bit ARM, so you can download the 64-bit installer.
I am sure that will work fine!
The 64-bit ARM world is standardized and I have never seen any compatibility issues like with 32-bit ARM.
The direct download link to the current version is:
https://www.syncovery.com/release/SyncoveryCL_11.12.0_arm_64.qpkg
Did you try this one?
Axel-Larator
Works
THX
