Ignore certain errors for email notifications
martman
Post by martman »
Good afternoon everyone
Apologies if this has been addressed elsewhere, but I'm having an issue with email notifications being sent for errors that should be ignored.
I have syncovery setup to perform a similar job to OneDrive (can't use OneDrive however) Syncovery works fine, but i get several emails (sometimes several in an hour) a day from Syncovery saying it's encountered an issue with a file/s and gives the error
The resource could not be found
In my profile, I do have error handling set to ignore ALL errors, I only want an email to be sent if Syncovery has an issue running the profile (scheduler error) or my service account that speaks to SharePoint has a login issue.
I did send a support ticket through and was told to check the Error Handling options, which has been done, and emails did seem to stop for a time, but they have started becoming more and more recent.
I would like Syncovery to email a central logging system (rather than myself) but can't enable this if i get multiple emails/day - the email alert should only fire when there is a serious error.
Can any one point me towards a solution to this ?
Thanks :D
Re: Ignore certain errors for email notifications
you can write your own script to determine which emails you want.
Please see "Send E-Mail Notifications Depending on Profile Results"
on
For example:
var NeedEmail:Boolean;
function OnProfileResults(const FilesCopiedL2R,FilesCopiedR2L:Integer;
                          const FilesToCopyL2R,FilesToCopyR2L:Integer;
                          const BytesCopiedL2R,BytesCopiedR2L:Int64;
                          const ResultString:UnicodeString;
                          const Error:Boolean):Boolean;
  Result:=true;
  NeedEmail:=Error and (Pos('Error to ignore',ResultString)=0);
function OnSendEmail(const ProfileName:UnicodeString;
                    var TheSubject:UnicodeString;
                    var HighImportance,UseDigest:Boolean;
                    var ResultSummary:UnicodeString;
                    const SomethingWasDone,ErrorHasOccurred:Boolean;
                    const FailedPathsCommaText:UnicodeString;
                    const StartedAt,EndedAt:Double;
                    var RecipientsCommaText:UnicodeString;
                    var SenderName:UnicodeString;
                    var SenderEmail:UnicodeString):Boolean;
  Result:=NeedEmail;
martman
Post by martman »
Thanks tobias
So far that seems to be working as expected :D
