Bypass the error "Abusive file cannot be downloaded from Google Drive"
Tần Quảng
Contact:
Post by Tần Quảng »
I'm using Syncovery 11.12.0.
Google Drive always scans user-uploaded files for viruses (privacy doesn't exist with Google), and it (almost always) fails with files larger than 25 MB or even when the Google virus scan server crashes, and those files, when downloaded, receive a warning that they couldn't be scanned for viruses or are even falsely marked as infected with a virus. For example: Wise Care 365.zip - This is a file I received from the "AOMEI 2025 Christmas & Happy New Year Carnival Giveaway" event not long ago.
With these files, I've tried many different syncing tools and they (including Syncovery) all failed to bypass this error and returned a download error (error code 403):
 (GET https://www.googleapis.com/drive/v3/files/1_ogvQgUb30jhs0mZ_mPJLPcaTOXY6TQ8?supportsAllDrives=true&alt=media)
08/01/2026 8:30:53 CH TSynGDrive.DownloadToStream:HTTP ERROR 403 Forbidden | {
  "error": {
    "code": 403,
    "message": "This file has been identified as malware or spam and cannot be downloaded.",
    "errors": [
        "domain": "global",
        "reason": "cannotDownloadAbusiveFile"
 (GET https://www.googleapis.com/drive/v3/files/1_ogvQgUb30jhs0mZ_mPJLPcaTOXY6TQ8?supportsAllDrives=true&alt=media) (ETGFTPErrorDoNotRetry)
08/01/2026 8:30:53 CH Local Stream Size Now: 0
8:30:53 CH.478 IP Exception (no retry): ETGFTPErrorDoNotRetry Abusive file cannot be downloaded from Google Drive: Wise Care 365.zip @ 0277AFA2, CP:CorEX4:Abusive file cannot be downloaded from Google Drive: Wise Care 365.zip
Exception Abusive file cannot be downloaded from Google Drive: Wise Care 365.zip at 0277AFA2.
Filename: ext://Google Drive/Storage (S꞉)/Documents/AOMEI 2025 Christmas & Happy New Year Carnival Giveaway/Wise Care 365.zip
Checkpoints: TGGetOrPutEX:Abusive file cannot be downloaded from Google Drive: Wise Care 365.zip
Incomplete file deleted from destination: S:\Documents\AOMEI 2025 Christmas & Happy New Year Carnival Giveaway\Wise Care 365.zip.url
I hope Syncovery can add a feature to bypass this download error.
Re: Bypass the error "Abusive file cannot be downloaded from Google Drive"
unfortunately if Google disallows the download, no software in the world can bypass this.
The best you can hope for is that Syncovery could silently skip the file. Is that what you want?
Tần Quảng
Contact:
Post by Tần Quảng »
tobias wrote: Thu Jan 08, 2026 6:44 pm Hello,
Apologies for the delay.
It's not "skip" but "bypass".
Based on the logs, I guess Syncovery uses the API during downloads, right?
After consulting some of rclone's discussions on the forum and GitHub, I found that they say adding the acknowledgeAbuse parameter during syncing might help bypass this issue.
I haven't tested it yet because Syncovery currently doesn't allow custom parameter configuration. Hopefully, you (if you're a Syncovery developer) can test it, and if it works, please proceed with the update.
Oh!
Interesting. OK I will test it!
First have to find some malware though to test it with ... hmmm ...
Tần Quảng
Contact:
Post by Tần Quảng »
tobias wrote: Sat Jan 10, 2026 3:09 pm Oh!
rclone has supported this for a long time, easily enabled via the --drive-acknowledge-abuse flag; I hope Syncovery will add it soon as well.
You can try the Wise Care 365.zip file. It's a safe file; I got it from the official event page "AOMEI 2025 Christmas & Happy New Year Carnival Giveaway," but Google—for some reason—reported it as virus-infected. If it really is virus-infected, then perhaps AOMEI was trying to spread a virus during their event. :?:
Tần Quảng
Contact:
Post by Tần Quảng »
tobias wrote: Sat Jan 10, 2026 3:09 pm First have to find some malware though to test it with ... hmmm ...
I discovered that I had forgotten to enable sharing for the file above. But when I tried to enable sharing, Google Drive immediately blocked access to it. This is the official download link for the WiseCare365.zip file, which was given away for free in the AOMEI 2025 Christmas & Happy New Year Carnival Giveaway event. When uploading this file to Google Drive, it will be mistakenly flagged as a virus. You can try using it to check the acknowledgeAbuse parameter.
Many thanks, I will work on this today and hopefully include the feature in the next update this weekend.
In version 11.12.1, you will now find the following checkmark on the second tab sheet of the Cloud dialog in the profile (Internet Protocol Settings):
- Allow Downloading Files That Google Considers Risky
Tần Quảng
Contact:
Post by Tần Quảng »
tobias wrote: Fri Jan 16, 2026 11:28 pm In version 11.12.1, you will now find the following checkmark on the second tab sheet of the Cloud dialog in the profile (Internet Protocol Settings):
I tried updating from 11.12.0 to 11.12.1, but after the update, it encountered an error that it couldn't retrieve file information from Google Drive and perform a comparison (version 11.12.0 worked fine).
Please try again. I suppose that occasional cloud outages can occur.
Please send a log file to support@syncovery.com with precise error messages if problems remain.
There has not been any change between these Syncovery versions except for the download of abusive files.
