Do not use on a server directly connected to the Internet
steinitz
Post by steinitz »
Looking at the downloads for a version for my Ubuntu server, I noticed the message:
Do not use this on a server that is directly connected to the Internet. Use it only behind a router within your LAN
Is that message referring to Syncovery in general or just the web interface? If the latter, two questions:
- how does one disable the web interface?
- how can one make the web interface secure?
Webmin, for example, demonstrates that a web interface can be relatively secure.
Re: Do not use on a server directly connected to the Internet
the warning is mostly about the web interface. But it is also a little obsolete, because newer Syncovery versions support using SSL with the web interface. When you open the non-SSL port 8889 from another machine (not localhost), then the SSL configuration page will be shown.
For extended security, you could use a web server's firewall to allow the Syncovery port only from specific IP addresses.
Or you can turn the webserver off when you don't need it, using
SyncoveryCL SET /WEBSERVER=OFF
