run profile with preview
rich.trefz@gmail.com
Post by rich.trefz@gmail.com »
Testing 11.9.6 for Linux. When I run a profile with preview, there is the option F7 (leave alone). On the Window version, I believe using F7 on a folder is recursive. That doesn't see to be the case for Linux.
Re: run profile with preview
interesting observation. I'll think about it.
In any case, you can use "Remove from list" instead by right-clicking the folder.
Ah, OK, Thanks. Sometimes I need to "cherry-pick" what gets uploaded and the recursive was handy.
Another situation where recursive matters ... If I wanted to bring back one folder, that had a bunch of subfolders (F8). Without recursion, I would have a problem if that one folder has 100 subfolders.
I don't think so, you can select and remove them via right-click.
If a folder is removed from the list, its children are too.
I wasn't clear.
I have a profile setup that could potentially copy 10,000 files. Left-to-Right. I saw one folder that I wanted to change to Right-to-Left. I hit F8 but its not recursive so it doesn't affect all the files in that one branch of the tree. So a few files at the top of the branch go R->L and all the sub-folders are still L->R.
OK. I'll work on it.
