Pascalscript execute fails
Wombat
Post by Wombat »
I'm trying to call a script from Pascalscript using this function.
function OnProfileStart:Boolean;
  Execute('/volume1/scripts/zabbix-db-backup.sh', 60);
  Result:=true;
This is on an Asustor NAS. Syncovery is running as root. The script has 755 permissions and runs fine when called from the cmdline. When called from Pascalscript as above I see this in the log
Executed /volume1/scripts/zabbix-db-backup.sh, Exit Code=1
If I try and use it from the Job -> Before field it also fails. I've tried prefixing the command with '/bin/ash -c ' but no luck there either. It even fails when the script simply contains an exit command.
The commands I have trying to run are all in /volume1/.@plugins/AppCentral/Syncovery/DATA/bin/authorized_cmdlines_syncovery
/bin/ash -c /volume1/scripts/zabbix-db-backup.sh
The command I want to run from this script is this:
/usr/local/bin/docker exec -it postgresql-server pg_dump --format c --user zabbix --dbname zabbix >/tmp/zabbix.postgresql.dump
I have no idea what I'm doing wrong. Any help appreciated. Thanks.
