Version 11.8.1 repeatedly detected as update
» by
Post by » by »
I updated to 11.8.1, but upon checking for updates, it detects 11.8.1 as an update all over again. Installed it a second time, same thing continues to happen.
Re: Version 11.8.1 repeatedly detected as update
thanks for letting me know. Unfortunately the build number wasn't increased from 100 to 101 in the software. So I changed the current number in the version info files back to 100. That means Updates from 11.8.0 to 11.8.1 are no longer offered either. But from older versions, they are.
It will be fixed properly in the next release.
