Automatic Updates
AndyMac
Automatic Updates
Post by AndyMac »
It would be really helpful if Syncovery could provide the option to automatically check for updates and ideally automatically install them. At least having the option to check and ideally show them with a notification (on a Windows notification if possible and similar on other OS, or at least using a popup message or message bar in the app when you open it) and ideally also providing this information in the email sent with status information.
Re: Automatic Updates
many thanks, I will consider it!
