Too many file versions
PeterC
Post by PeterC »
I'm trying to setup a profile that keeps 8 versions of the backup files. My settings are shown here in the below screenshot.
20250712 versions.jpg (227.93 KiB) Viewed 48577 times
My problem is the profile is keeping many more copies than the configured 8, as shown in the above screenshot that highlights 15 copies of 'Budget'.
Re: Too many file versions
thanks for the report. In my tests, this works correcty. Can you send a log file to support@syncovery.com so I can see your complete settings and any possible errors deleting the file?
Thanks.
PeterC
Post by PeterC »
Email with log file sent. Thanks.
many thanks! The new version 11.6.4 should fix this now.
