Settings SMB share
Alex.Ra
Settings SMB share
Post by Alex.Ra »
I am using Syncovery version 10.18.1 build 280
The SMB share connection is not working
When configuring Additional Destinations, I specify SMB share, but the program tries to connect via FTP. In the profile, the connection string looks like this:
<AdditionalDestinations>{"mode":"5","atmbeh":"0","flags":"0","destinations":[{"path":"smb://10.40.1.3/test_path","flags":"1","ftpmethod":"0","ftpflags":"536903680","ftpuser":"testuser","ftppass":""}]}</AdditionalDestinations>
Re: Settings SMB share
Thanks for the report. That's quite possible. Please create a separate profile for the second destination.
You can edit the profile name, change the destination and click OK to create a duplicate.
I also released Syncovery 11 yesterday with numerous improvements and a much better GUI, but the "Additional Destinations" feature is about the only thing that wasn't touched.
I tested this here now, and it works fine.
After entering the smb:// path, you must click on the Protocol button to choose the SMB protocol and specify the network credentials.
