Syncovery adds garbage names for deleted files
singhs_apps
Post by singhs_apps »
I have been using Sncovery to sync and back up my files on macOS and Windows for many years.
My normal process is to sync/move/mirror hard disks to hard disks. To ensure that no important files are lost, I use the ‘move deleted files’ settings in the sync window dialogue to move the deleted files to specific folders in case I want to retrieve them at a later date or delete them manually once I no longer need them.
Last few years I see that Syncover adds garbage/arbitrary names to these deleted files.
For example
Filename.x1uMJUUY.EXT
Filename.x1uMGtuK.EXT
How do I ensure that Syncovery retains the original file names without adding any garbage/arbitrary names to the deleted files?
Re: Syncovery adds garbage names for deleted files
This is the encoded deletion timestamp.
You can remove the checkbox ‚Remember deletion date and time‘.
But if you use the Restore Wizard to restore files, Syncovery will automatically decode the filenames.
singhs_apps
Wonderful.
Thanks. I have never used syncovery to recover the deleted files. More often than not, the recovery is just manual.
