Dear Syncovery team,
I have quite a few of $syncovery extension files in my backup target, I assume due to several botched transfer that I had due to network, sample:
'220718-u161125.s1555998.$syncovery''
some of them are 0 size files, others not. Can i delete them safely?
Also, sometimes the UI warns me that it found unencrypted files on the right side and that needs to encrypt them. I am a bit concerned about that since I thought files were encrypted prior to upload.
Attaching an image of the message about encryption
$syncovery files
$syncovery files
- Screenshot 2025-06-24 at 15.30.06.png (22.25 KiB) Viewed 21674 times
Re: $syncovery files
Yes, you can delete them!
Concerning the encryption message, we would need to look in the log file, you could reply with No and then cancel the job and then look for lines about filename encryption in the log and/or send it to support@syncovery.com.
Hi Tobias, I was planning to do so, but I updated first to the latest release (11.5.2) and now I am getting this error when I launch the profile
- Screenshot 2025-06-24 at 18.13.45.png (29.52 KiB) Viewed 21667 times
I'll send you the logs via email
many thanks. The new version 11.6.2 fixes the crash!
Thank you so much Tobias. Incredible support!
Crash is fixed in 11.6.3. Thank you so much!!
