Please help me delete on scheduled/unattended run
ChaosX
Post by ChaosX »
Log shows: confirmation to delete files is missing in profile's Safety settings
What have I overlooked?
Re: Please help me delete on scheduled/unattended run
in the last screenshot, you did not place the checkmark:
X Unattended File Deletion Allowed
In addition, please note that the limits of 20% and 1000 can also cause deletions to be disabled if there are too many files to delete. That means if you make an artificial test with only 20 files and you delete half of them, Syncovery won't do it because it's over 20% (unless you change the percentage).
ChaosX
Post by ChaosX »
Bumping that up to 40% did the trick. Thank you. Seems I'm easily confused with all the safety layers.
