B2 - Exact Mirror - Left to Right - Not deleting folders on right side
brink668
Post by brink668 »
I am syncing Left to Right (Exact Mirror) and folders that no longer exist from the Source Side (Left Side) are not deleting on the Target (Right Side) in B2. It appears that files are being moved/deleted correctly but not the folders.
Any option I need to select to get the folders to delete as well? Trying to keep the exact mirror setup.
Re: B2 - Exact Mirror - Left to Right - Not deleting folders on right side
Syncovery does not create or delete folders on B2.
The existence of folders is merely implied by files having a certain path.
If you copy to a fresh bucket only with Syncovery, you should not have any issues. How were the folders created?
brink668
Post by brink668 »
Your program created them on B2 S3.
H,
so you are accessing B2 using the S3 compatible API only?
The "empty folder" emulation logic in Syncovery is applied only via S3, not the native B2 API.
