FTP connection problem, run again with /ACCEPTSERVER
Jean-Michel
Post by Jean-Michel »
Hi
I'm trying to setup a new FTP destination which is using TLS on port 21
But I get the following message when I try to browser the destination:
ERROR: Connection problem: ftp://xxx.xxx.xxx.xxx: ERROR: SSL Server unknown - run again with /ACCEPTSERVER command line parameter
I have no idea what it means and what settings I should change
Current settings:
Protocol: FTP
URL: ftp://xxx.xxx.xxx.xxx
Port: 21
Passive mode: checked
Secure Transfer: Checked
User ID and password: set
Security:
Security mode: Explicit TLS
Auth Cmd: tested Auto and TLS
Version: tried all 3
Setup worked fine on Filezilla client
Any suggestion welcomed
Jean-Michel
Re: FTP connection problem, run again with /ACCEPTSERVER
Ah, found that thread: viewtopic.php?t=839
So it looks like it is about accepting the server's certificate on first connection which is something I did on Filezilla
Is the only solution to run with /ACCEPTSERVER which would mean it would accept for every server
It would be great to be able to willingly accept once
Jean-Michel
problem solved using the domain name instead of the IP of the server
thanks for the posts! Yes if you use a domain, Syncovery can usually verify the SSL certificate automatically. But not with an IP address, because SSL certificates are bound to domains, not IPs. Theoretically there should be a prompt, allowing you to confirm the certificate. It's possible that it doesn't appear in some cases. I will look into it.
