SyncoveryCL start remains in foreground on Macs...
User avatar
phredd
Post by phredd »
I've been able to programmatically set up a properly configured profile using SyncoveryCL, but I've been unable to use it to launch the scheduler without console output grabbing the foreground of a terminal session. Further, escaping the console after launching the scheduler causes the scheduler to shut down.
I've looked and there doesn't seem to be an active LaunchDaemon or LaunchAgent entry for Syncovery even when the scheduler is up and functioning. I do see entries for Syncovery when I use launchctl list, though: application.com.company.Syncovery.766576162.766576167
Any suggestions for properly launching the scheduler from a script on a Mac?
Re: SyncoveryCL start remains in foreground on Macs...
there are two different schedulers to choose from:
a) the background scheduler, which is an app: BackgroundScheduler.app hidden inside the Syncovery bundle. You can start it like any other app:
open /Applications/Syncovery.app/Contents/MacOS/BackgroundScheduler.app
b) the service scheduler. This must be chosen and installed on the Scheduler tab sheet in Syncovery. It will copy SyncoveryCL to the PrivilegedHelperTools and rename it to SyncoverySRV. I think you can start and stop that like any other daemon.
User avatar
phredd
Post by phredd »
Thanks!
I'm opting to launch the background scheduling app via launchctl.
this is a macOS problem, and ChatGPT recommends to use this to open the app detached from the Terminal:
open -a "/Applications/Syncovery.app/Contents/Resources/BackgroundScheduler.app"
