Cannot 'see' the bottom of the Profile Settings dialogue box
Alice
Post by Alice »
hello, hope all good :-)
Dell UltraSharp U3219Q 32in Monitor / 1920x1080 / W11 / Custom Scaling set to 150% / Syncovery 11.3.2
with that arrangement I can't see / interact with the last couple of lines in the Profile Settings dialogue box. So I cannot 'see' the 'Ok' / ''Cancel' / 'Save as' buttons, unless I set the Windows Taskbar to 'Auto Hide' (which I don't particularly want to do).
Any chance the Profile Settings dialogue box could be 'scalable', ie I could drag its right-bottom edge upwards to reduce its size please or use 'alt+space bar' then the 'Size' option ?
thank you.
Re: Cannot 'see' the bottom of the Profile Settings dialogue box
such an extreme monitor configuration is not really supported.
With Full HD, you should have a magnification of 100%.
However, you can reduce the Syncovery GUI size via the Gears toolbar button, which will give you the menu item "Enlarge User Interface", where you can enter a number such as 75 (percent). It won't be pretty but maybe it will work.
Alice
Post by Alice »
Ok, thank you.
I set the 'Custom' / 'Enter User Interface Enlargement Percentage (50-400)' to :
96
and that seems to do the trick.
