Download v11.2.*?
» by
Download v11.2.*?
Post by » by »
Is it possible to obtain older v11* versions like v11.2.2 or v11.2.3? I'm on v11.2.5 and Syncovery is so slow it's unusable during the file list building process. I know there is an update but I can't waste any more time on this.
Re: Download v11.2.*?
if you used Help->Check for Update, you will find the versioned Setup programs in your Downloads folder.
You can download previous builds from our web site using the build number, for example:
https://www.syncovery.com/release/Synco ... p11045.exe
for version 11.2.3
But I don't think it's the version. There are probably other circumstances that changed. Or the cloud servers are having issues (if you sync with cloud).
Please send log files and screenshots to support@syncovery.com.
When Syncovery is slow, you can get an Activity Report that helps diagnose the issue. For foreground jobs, hit Ctrl-F2 to get the report. For background jobs, right-click and choose "Diagnose Activity".
» by
Post by » by »
I knew about the files in the Downloads folder, but I clean them up regularly.
I think it may be the version because it happens with both cloud and local backup.
Thanks!
