File selection while sync by web browser
KennyLin
Post by KennyLin »
I know it doesn't have the attended mode on Web browser for Linux.
But I need to let user select the specific file to sync, not all files in the sync folder.
Is there any way to achieve this goal?
Re: File selection while sync by web browser
Currently the only way is to type the filename into the "Inclusion Masks" field.
You can type the name alone, or include a sub-path starting from the profile's base path.
For example:
Invoice-2025-04-05.docx
or
/Invoices/2025/Invoice-2025-04-05.docx
To avoid creating empty folders due to the selection, I recommend removing the checkmark "Create Empty Folders" on the Folders tab sheet.
I hope to improve the web GUI further in the future. The mode "Run With Preview" is similar to attended mode, but you can't make any choices in the preview.
