Program version update issue
Dan Glebitz
Post by Dan Glebitz »
Hello, Registered user of v11 here. I have just run 'Check for updates' from the main program and it found a new release. Current version was: 11.1.4.41. Running check update downloads and installs v11.2.0.42. This is confirmed after the update completes via the checking the ABOUT box.
However, if I check for updates again, it still says that an update is available and that update is the SAME version that I have just installed.
I have rebooted my PC and same result when I check for updates. It says update is available, but its the same version I have just upgraded too.
The program is running fine and without issue.
Any clues?
Thanks.
Re: Program version update issue
thanks, I have fixed it!
Dan Glebitz
That was quick.
Fix confirmed.
Great service, and a great invaluable program.
Thank you.
