FOLDER DELETE, but FILE MOVE, can't do it
Contractor5Prepays9
Re: FOLDER DELETE, but FILE MOVE, can't do it
Post by Contractor5Prepays9 »
ok, let's try again (I have colonoscopy thursday, my body system is not clicking on all cylinders :-), brain fog)
on left side, create a new folder, \TESTING
in that folder, put a file, TEST-TEXT.txt (put some text inside it, as some zero-length files don't get copied)
run your syncoronization, then see that it shows up on the RiGHT side.
then delete the TEST-TEXT.txt file on teh left side
then re-run your synchronization, RUN IN ATTENDED MODE. it should then give you a list of what will happen.
you should see that TEST-TEXT.txt is not present on the left side,and should be marked for deletion on the RIGHT side.
then proceed, and then see if an \ARCHIVE folder got set up on the right side, and if TEST-TEXT.txt is present in that folder
hopefully this can be figured out :-)
richardlevene
Post by richardlevene »
Ok never mind. I found it... "Archive" was working which made me think ok maybe i don't actually know where "/Archive" goes.
I was expecting it to put it at the root of the folder that was set as the specific destination on the sync.
ie i was testing like this
L = //projects/projectX
R = //projects/projectX
So i assumed projectX was seen as the root and was expecting the "/Archive" result to put it in //projects/projectX
But it created the folder and moves the files within //projects/
Thanks,
Richard
Contractor5Prepays9
ok,now that you found it, does it have prior deleted ones in it? or, test to see if it accepts new deletions?
richardlevene
yep all good
sorry for the late reply. Please take a look at the examples on the dialog.
To put the Archive folder at the profile's base folder, you need to type
./Archive
As opposed to /Archive, which goes to the root of the bucket/container.
richardlevene
Thanks Tobias!
