Not Found for URL Error w/ S3
rbjdpa
Post by rbjdpa »
i'm getting multiple errors after transferring data to S3. Below is an example of the error in the log.
GetS3SizeAndDate error: Not Found for URL: https://transferbucket.s3.amazonaws.com/transferfolder
HTTP Headers: HTTP/1.1 404 Not Found
x-amz-request-id: P3050X8EY6AXTXJ5
x-amz-id-2: /4zksSxbYWigHFrgOkJ5C30oA5LMZMOzMBdW33+iNPSzfzJdqH9ytJeVaGO3GKdim7+cOeWBgic62/zWZhdKAFBBDLQrUQ05
Content-Type: application/xml
Transfer-Encoding: chunked
Date: Fri, 13 Dec 2024 21:59:36 GMT
Server: AmazonS3
Failing after exception: Not Found: Http Result: Not Found
Does this mean the file transferred but failed a validation check, or is something else going on? Out of 50k records, there's a few hundred with this error and I'm not sure what it means.
Re: Not Found for URL Error w/ S3
this is not an error, just excessive logging. It means nothing and can be ignored.
Subfolders are usually represented by dummy, empty items. This error occurred when Syncovery checked if such a dummy item existed or not.
I believe that the latest Syncovery version tries to avoid unnecessary logging for such items, but I will double-check it.
the new version 11.0.19 reduces unnecessary logging in more more case, maybe that's what you need.
