Troubles with SET /SYNCOVERY_HOME
Nei
Post by Nei »
Hi there,
I extracted https://www.syncovery.com/release/Synco ... Web.tar.gz in /opt/Syncovery/ and initialized it with:
./SyncoveryCL SET /SYNCOVERY_HOME=/home/user1/.Syncovery /WEBSERVER=localhost
and get this output in the terminal
19:08:38 SyncoveryCL v9.10
19:08:38 Initializing
Wrote /etc/SyncoveryCL.conf with workdir=/root/.Syncovery and tempdir=/tmp/
Changed perms of /root/.Syncovery to 777, result code =0
19:08:40 Log folder: /root/.Syncovery/Logs
19:08:40 Configuration File: /root/.Syncovery/Syncovery.cfg
19:08:40 Storing global settings:
19:08:40 SYNCOVERY_HOME=/home/user1/.Syncovery
19:08:40 Configuring web server for localhost, port 8999.
19:08:40 Web Docs Path: /opt/Syncovery/WebDocs
19:08:40 Username: default
After starting the application I expected .Syncovery in /home/user1/.Syncovery but it is not there. Instead, I find .Syncovery here:
/.Syncovery/
and here:
/root/.Syncovery/
Perhaps I misunderstood something in how to configure Syncovery. Any hint to sort this out is highly appreciated.
Thanks in advance,
Nei
Re: Troubles with SET /SYNCOVERY_HOME
SYNCOVERY_HOME can be set as an environment variable but not on the command line.
But nowaways you should not use it at all and just edit /etc/SyncoveryCL.conf instead.
Nei
Post by Nei »
Thanks Tobias for the explanations, but sorry, I still don't get it.
In the documentation is written:
SyncoveryCL will create a .Syncovery folder for configuration, logs, and databases in the HOME folder. It depends on the HOME environment variable. You can also use SYNCOVERY_HOME, which takes precedence. HOME should not be /.
When I initialize Syncovery I get:
/root/.Syncovery/
an this is fine with the default in /etc/SyncoveryCL.conf.
However, when I start the Syncovery app the first time
/.Syncovery/
is created and contains Syncovery.ini and Syncovery.ini.bak.
As far as I understand the documentation quoted above .Syncovery should not be in /.
Could you please enlighten me?
Maybe it didn't find the environment variable that it was looking for.
Please specify the folder you want in
Hello again,
the documentation is trying to say that your HOME variable should not be empty or equal to /.
The Syncovery.ini is just a very small file and it could be that it is stored in your HOME folder. But the real data will be saved in the proper location.
