When using the listening service on both sides, it would great if the File Attributes option worked even when the underlying endpoint (SFTP) is blind to file attributes. I treat hidden files specially and the backup needs to sync hidden attribute changes as well as copy them. I understand that the service will see file attributes.
Currently the File attribute tag does not appear to work when I am copying SFTP -> disk, listening both sides with the listening service.
I can live without this as I can use something else to index all attributes (VoidTools Everything) but it would be a great feature.
File Attributes
Re: File Attributes
in what way could attributes "work" if the protocol does not support them? I don't think that the Windows "hidden" attribute can be transmitted over SFTP.
Re: File Attributes
I am using SFTP connected to a windows drive with the files visible to the remote service (at the SFTP end).
If not already doing so, the remote service at the SFTP end could read and send the file attributes. The other end may not be processing the attributes/attribute changes as it sees that SFTP is selected even though it has the information due to the listening/remote service.
Re: File Attributes
yes, for listing purposes, the attributes should work fine over SFTP.
Maybe the problem is that for files to be considered hidden, they have to have that attribute on both sides?
Re: File Attributes
This a real problem for me. I need an exact copy LHS (Windows + SFTP) -> R (Windows) with the hidden attribute being (i) copied on the first copy; and (iii) being updated when it changes on the LHS. I hadn't noticed the issue with a backup that I was taking. Any help here would be very much appreciated.
- Clipboard Image (2).jpg (85.22 KiB) Viewed 9926 times
- Clipboard Image (1).jpg (82.42 KiB) Viewed 9926 times
