Batch files
Bob
Batch files
Post by Bob »
is it possible to run a batch file and wait xx seconds before starting the backup and after that run another batch file ?
The first batch file will wake on lan a destination pc and the last one will turn it off.
Bob
Re: Batch files
yes, please see the dialog "Execute before/after", which you can get via the checkmark on the "Job" tab sheet in the profiles.
The special directives for delays are explained on the dialog.
For example:
execute before:
*060*C:\Scripts\WakeRemotePC.bat
execute after:
C:\Scripts\ShutdownRemotePC.bat
If the batch file has only one line, you may be able to put that line into Syncovery directly.
For example:
SHUTDOWN.EXE -m \\BackupPC
Bob
Re: Batch files
Post by Bob »
Thank you, it works !
