Logged into the wrong OneDrive Acct - how to change
binser
Post by binser »
since I have several onedrive accounts, I logged into the wrong onedrive account by mistake when running a profile.
How can I now log in to the other OD account with this profile?
Can I set Syncovery to somehow prefill an email into the authorization page so this problem won't arise again?
Thanks for your great software. It looks much more pleasing now too than previous iterations. :)
Re: Logged into the wrong OneDrive Acct - how to change
thanks for your post!
You can connect to a different OneDrive account by typing something different into the field
Account (opt.)
on the Internet Protocol Settings dialog.
Whatever you write there has no real meaning, so you can type whatever you like.
You can also let Syncovery forget all cloud connections via the button "Forget Cloud Access Tokens" on the Program Settings dialog, tab sheet Cloud.
You can also delete just the incorrect connection from Vault.ini in the same folder where Syncovery.ini is.
For example, delete the whole section [onedrivebus_abcxyz].
See also
https://www.syncovery.com/documentation ... d-storage/
