Default Profile Settings
fletch
Post by fletch »
SO many settings - awesome - but since I end up tweaking some of the same Advanced settings on most profiles I create, I wish I could make that the default setting for all new profiles.
Re: Default Profile Settings
to custimize default settings, you can create a profile named default and export it to a file named presets.ini.
This file then needs to be copied into the Syncovery program folder, which is usually
C:\Program Files\Syncovery
fletch
Post by fletch »
Hey! Thanks for that tip, I'll try that.
