Change one filetype on-the-fly
a.devecerski
Post by a.devecerski »
Hello everyone
I would need to make a backup job for a folder structure containing different file types where one of them should be changed in the backup location (for example, all .DOC files should be renamed to .BAK). All the other files should be backed up unchanged.
Is that possible?
Regards
Re: Change one filetype on-the-fly
yes, you can do this with a PascalScript.
Please see
In the following example, I chose lower case extensions because that's the standard nowadays. However it will recognize an uppercase .DOC extension too.
  if isFolder then
    Result:=FileName
  else
    if LowerCase(ExtractFileExt(FileName))='.doc' then
       Result:=ChangeFileExt(FileName,'.bak')
    else
        Result:=FileName;
The script is pasted into the profile via the checkmark "PascalScript..." on the "Job" tab sheet.
a.devecerski
Hello Tobias, thanks for the quick response
As luck would have it, I need this backup job to run on our backup QNAP NAS (TS-1635AX), with ARM CPU.
And attempting to add Pascal script resulted in "PascalScript is not supported on this CPU type" error message.
I've tested the script on a different, x86 powered, NAS and it works like a charm.
Is there any other way I could accomplish this directly, on the first mentioned NAS?
Thank you for the assistance
Regards
unfortunately, the PascalScript language is currently not available for 64-bit ARM (AArch64).
I hope it can be implemented, possibly in the second half of 2024.
a.devecerski
tobias wrote: Fri Feb 23, 2024 10:15 am I hope it can be implemented, possibly in the second half of 2024.
Kind of hoped v10.12.3 upgrade will bring that functionality :(
Thank you Tobias
it's not easy, as the following needs to be translated to 64-bit:
https://github.com/modulo7/pascalscript ... ce/arm.inc
I will try to give it a higher priority. I am actually very interested in this. MacOS customers need it too, although for another good while they can just install the Intel version of Syncovery on their Apple Silicon Macs.
a.devecerski
tobias wrote: Tue Feb 27, 2024 12:50 pm Hi,
I'm sure it's not easy (but maybe it was already in preparation or something like that...).
While we're at this, not that it's problem or anything, are there any Release Notes or What's New for new versions or we just look around & try new stuff?
Haven't been able to find them on your site.
Again, thank you very much Tobias
