do not copy files which is 2months older than current month
jyrs
Post by jyrs »
source folder:
has folders/files up to 1 year
destination folder:
recurring copying every 3 hours daily.
I want to copy folders/files which is not 2 months older than current.
because of disk space limit.
how do I set the profile?
Re: do not copy files which is 2months older than current month
the easiest way is go to Masks & Filters -> File Age and Size and choose:
File Age: less than 62 days
But maybe this is not exactly what you want.
Do you always want complete months?
Should Syncovery delete a complete month from the destination when the next month has started?
In general, if you use Exact Mirror mode, you can click the Configure button and choose:
X Remove Files That Do No Match the Filters from Destination
If the simple File Age mentioned above is not sufficient, a customized filter can easily be written in PascalScript.
