- Syncovery_2024-01-07_23-47-38.png (11.78 KiB) Viewed 21093 times
Backups to S3 failing
See attachment
Re: Backups to S3 failing
Apparently the new OpenSSL version 3.2 doesn't work on some systems. You can go to the Program Settings dialog, tab sheet Cloud, and choose:
X Use SecureBlackBox SSL/TLS rather than OpenSSL
Your change to SecureBlackBox SSL/TLS fixed the problem. Thanks Tobias
